How do I get Original Estimate and Work Logged on detail screen?
Dale Bronk
We us scrum.  The detail view the shows in the right pane...  How can I add Original Estimate and Work Logged to this view?
Walter Buggenhout
May 13, 2017
You can't, actually. You can add them on your Board Cards, however - if that might help as a workaround.
To do so, go into your board configuration, select 'Card layout' and add them there.
