How do I get a list of active components in JIRA and export them?
JanaW
February 17, 2015
We are deprecating a development tool we use and moving to JIRA. I would like to be able to get a list of active components in JIRA to compare to our dev tools components to make sure JIRA is updated with all that we need. How do I get a list of the active components in JIRA and then export them to excel?
2 accepted
10 votes
Michelle Rau HP
January 15, 2019
I tried something a bit goofy but it worked surprisingly well for a simple list of components.
  1. Created a filter for "all issues"
  2. Created a dashboard and added the Heat Map gadget
  3. In Heat Map gadget settings,
    • Project/filter field = my "all issues" filter
    • Statistic type field = Components
  4. Save gadget settings and you should see the heat map in your dashboard.
  5. With your mouse, select all the components in the heat map list, then copy (control+C)
  6. Paste into MS Word. I got a bullet list, one bullet for each component
  7. Format and sort the list as needed, then copy/paste into whatever (Excel, PPT, email, etc.)
I was able to use the heat map gadget to create a list of labels as well.
Updated: This technique would give only the components actually used in issues included in the filter (assuming that's what the original question meant by "active", or "in active use").
Updated again:  Please note, this is a "quick and dirty" technique rather than a more structured query or view. See the other answers for more "official" solutions.
JanaW
January 16, 2019
Thanks Michelle! Appreciate the answer.
Like Mani Pajouh likes this
Mani Pajouh
March 13, 2019
Thank you! It works!
Amit Gala
July 12, 2019
Thank you. Super helpful.
Steven Rhodes
@Michelle Rau HP It does indeed work, but the components are not ordered and the formatting means when I paste, it also looks like a heat map retaining formatting, or without formatting all on one line. I have 131 components in one project, some of which have spaces in the title which makes the task of sorting it harder.
Michelle Rau HP
April 2, 2020
That is true @Steven Rhodes , I used MS Word to strip the formatting and sort the list in alphabetical order. It's true this is a "quick and dirty" technique rather than a more structured query or view.
Oxana Stoupakova
June 9, 2020
Thanks, Michelle. Works like a charm!
Like Michelle Rau HP likes this
Geetanjali Verma
February 15, 2021
Super helpful and easy!
Bob Swift
February 17, 2015
getComponentList from JIRA Command Line Interface (CLI) produces a csv file that can be imported into Excel. Use with runFromProjectList to collect information from multiple projects into a single csv file.
JanaW
February 18, 2015
Thank you Bob:)
4 votes
Priyanka Lavania
June 19, 2016
Hi Jana,
There is another easy and economic way of doing the same. you can run below JQL:
component is not EMPTY
Above will result in all the issues which are using the component, post which you can export the issue result in an excel and remove duplicates(data->remove duplicates), by this you will have a list of unique components currently in use.
If you want to list out all the components in JIRA Project, then you can simply navigate to the project->Overview->Components
It will list all the components which you can simply copy and paste in an excel. you will have the entire component list.
Hope this helps.
Balvant Gmail October 9, 2018
some extent it is ok, but what about if 500+ projects?
Thanks anyway.
Like JanaW likes this
JanaW
January 16, 2019
Appreciate the answer but we too have A LOT of projects which makes it more difficult. But more importantly, I don't just want to see those that are being used, but those that are NOT as well so that we can remove them or question if they are still valid. It does however get me closer than I was when I posted this question:) Thanks for your time.
Reva Tolliver April 26, 2021
I used Confluence  and put a two-dimensional filter in there with the following query:  Component is not empty.  I also filtered by project and issue type but that is optional.
I then saved and exported the page to Word, instant beautiful table to be used anywhere I needed it.
Note:  This renders very well for large numbers of issues.  There are over 47k issues in my filter.  Good luck!
Deleted user April 18, 2019
Another way to access all of the components in a project or projects is to conduct a basic search in issue navigator.
Go to your search bar and type issue navigator and hit return/search - see image below
Once in issue navigator use the basic search and do the following:
  1. Select your project from the left hand side, or select all projects in your organization where it says Project: All
  2. Over on the more section, select component as a search criteria (you may have to search for it) - see image below
  • Notice under Project: All there is a new drop-down listing all components
    (far left of image below)
  • Just grab this drop-down and you're all set - there are your components currently used somewhere in the project or projects you've selected. - see figure below
Hope this helps!
Priyanka Lavania
April 18, 2019
Not sure how it will list Components that are not used in any issue (basically won't pull inactive components)
The query mentioned above pulls a holistic list of components, used or not used on any issue type. If created, it will populate in this list. In fact, if you had a project with no issues and only components, the query will render results, those of which are the components that exist within the project.
Like Priyanka Lavania likes this
Priyanka Lavania
April 22, 2019
Ah so it will only populate the list of components to select from, not the search result.
Manually need to write down the components. again a tedious task if there are 100s or 1000s of components. But for few it is a good solution.
JanaW
June 9, 2020
Appreciate all the suggestions but those are steps I had done before posting the question and should of stated that so not to waste others time.
I would like to see Atlassian offer an easy way for an administrator to either generate a report or export active components, including those that are not actively used in projects. It's a way for us to 1) identify a holistic component's list, but also archive those not being used. It would also be nice to view or generate a report that lists components and then the project that uses them. This would be helpful when a name of a component needs to change/renamed, it would be an easy way then to quickly identify and go to the project to update the component name there.
Like # people like this
