How do I get a response in Rest API for creating a new issue?
Pradeep A
Hi Im working on a project where I need to integrate teams with Jira and notify it whenever  a issue is created. I tried using webhooks but not all events are getting notified. So I wanted to try it with Rest API. So How do I get an API response for the issue I have created?
Daniel Ebers
June 20, 2021
Hi @Pradeep A
when working with API on a remote service you would have to query it in order to get back the data you are looking for. From my believe there is no ready-made solution available - you would have to do it all on your own in regards to a API implementation.
However, I am wondering if it is the MS Teams you are integrating with - in case it is probably an App from Marketplace which did all the hard work for you already could be an alternative:
https://marketplace.atlassian.com/search?query=teams
You could check them.
Daniel
Pradeep A
I tried using the Microsoft 365 app for jira. When I try to login MS Teams from Jira it shows 403 forbidden error. Any insights?
Daniel Ebers
June 27, 2021
In case this error persists please feel free to raise a request with their vendor.
I do not use it personally and cannot reproduce the issue therefore.
Vero Rivas
June 17, 2021
Pradeep A
Hi @Vero Rivas  I have already took a look at it, But I want to create an issue from Jira and get the issue details through the API. I need to receive the issue details, So that I can work with my third party app. Hope you can Understand my scenario. Please revert back if you have any solutions.
Thank you
Learn more
