I have a checkbox custom field named 'Fruits' and value Requested.
And other 3 more custom fields.
When user clicks Requested it should shows other 3 custom fields else not.
Prior to that all 3 custom fields must be hidden.
You will need some code to do that. Either a custom field type that can support it, or injected javascript.
The Behaviours module in the script runner add-on can do this too, it does the javascript for you.
Yes Nic,
I am using this below code using JavaScript through the plugin
function fruitnewField(){
$('#customfield_14201-1').click(function() { // Fruit cf
if (document.getElementById('customfield_14201-1').checked){ AJS.$("#customfield_14202").closest('div.field-group').show(); //other cf
AJS.$(":input[name='customfield_14203']").closest('fieldset.group').show(); //other cf
AJS.$("#customfield_14204").closest('div.field-group').show(); //other cf
else{
AJS.$("#customfield_14202").closest('div.field-group').hide();
AJS.$(":input[name='customfield_14203']").closest('fieldset.group').hide();
AJS.$("#customfield_14204").closest('div.field-group').hide();
When I checked check box other cf are shows and when I unchecked it cf are hides.
But the problem is how to hide these other custom fields on the load of create screen when the check box is unchecked defaultly.
