How do I integrate JIRA with a private room in HipChat?
Jason Kelsey
January 14, 2015
We have a global integration setup between our JIRA and HipChat accounts, and can see the public HipChat rooms when matching a project to a chat room, but not the private rooms. How do we get the option to set the integration on the private rooms?
5 votes
Tanguy Crusson
January 19, 2015
@Jason Kelsey you cannot currently map a JIRA project with a private room, but we are planning to release this feature in the near future. I will post an update here when it's out, stay tuned!
Oleksandr Diudiun
Waiting for this!
Shawna Schnorr
Since we were able to do this until quite recently, we are definitely looking forward to reinstating this functionality. Is there a place we should go to vote for it?
Tanguy Crusson
January 20, 2015
Hi @Shawna Schnorr, no need to vote for it, it's already in flight, and I've seen demos of it!
Paul McGuire
February 3, 2015
Oh no - I'm hitting the same problem, looking forward to this being possible.
Indre Solodov
February 7, 2015
Need this asap!! Thx
Tanguy Crusson
February 9, 2015
@Oleksandr Diudiun. @Shawna Schnorr @Paul McGuire @Indre Solodov we just shipped this to JIRA Cloud (it was already available in JIRA Server through the "HipChat for JIRA" plugin in the Marketplace). See Anatoli's response below.
Anatoli
February 9, 2015
Jason, we deployed the new version of the plugin were you see private rooms after you log into HipChat:
image2015-2-10 17:34:33.png
Once logged in you can see private rooms - they are marked with a padlock:
image2015-2-10 17:17:42.png
Ed Millan
March 25, 2015
How about if when you click on Log In, you never get the option to enter your Logon credentials? I just gives you a loading Icon and sits there...
Anatoli
March 25, 2015
Hi Edwin, you might be hitting this problem: https://answers.atlassian.com/questions/13416609/answers/13418253 Just connecting the JIRA to HipChat should fix it.
easymile_pejvan
April 28, 2015
I'm facing the same issue, but I'm running JIRA on our own servers. I'm wondering whether disconnecting and re-connecting JIRA and HipChat will mean that I will have to reconfigure all the integrations or not ?
Anatoli
April 28, 2015
Anatoli
March 25, 2015
Ed Millan
March 25, 2015
We're having an issue of after clicking on the Log in option it just sits there, has anyone else experienced this?
Oleksandr Diudiun
+1
kylewernham
January 19, 2015
I just went to try and hook a Confluence space, JIRA project and Hipchat room up together but since they're private, I'm unable. I look forward to this feature! Thanks for posting, @Jason Kelsey .
Gustaf Sahlstrom January 19, 2015
@Tanguy Crusson , will do that. Thx.
Tanguy Crusson
January 19, 2015
@Gustaf Sahlstrom if you face an issue moving from the older JIRA integration to the new one, please raise a ticket on help.hipchat.com, providing as much information as you can, and we can help you there. We built it so it happens automatically, but maybe there is a glitch?
Sudipto Aich
January 15, 2015
This seems odd that tools (Hipchat + JIRA + Atlassian) are not hooked up better!! I cant even choose which rooms or get a private room
Gustaf Sahlstrom January 14, 2015
+1, having the same problem. Seems that the integration is done slightly differently now, with a plugin. This caused my old APi integration to stop working, and now I can only find the open rooms that we have in HC.
Read the story
