I am trying to make an issue "story" move from one status to another automatically based on a date condition or criteria.
For e.g. let's say a story is sitting in "To Do" status and there is a custom date field which is already set based on the creation date of the story. I would like that story to move to "In Progress" status automatically if 4 days have passed from the created date or that custom date field.
I know that JIRA workflow has the trigger features but that only works based on development tools (Fisheye/Crucible, Bitbucket and GitHub).
How do I do this? Is there any way?
FYI - I have the following plugins in JIRA that I use to configure workflow
Any help would be appreciated. Thank you!
Shahriar
I don't think this can be achieved via a workflow post function. In order for a post function to run, a previous step in the workflow needs to trigger it and post functions cant be scheduled.
I think your only option would be to add an additional add on that brings automation functionality to your projects. Listed below are two addons I highly recommend
#1 Automation for Jira
This is a powerful add on that adds automation to all of your Jira projects. You can have automations based off of comments, transitions, issues being created, scheduled automation's and much more. For this use case you would use the scheduled trigger and have it constantly run checking the date field to see if its reached the right date.
AFJ does have a free version but it limits how many times an automation can run a month.
#2 ScriptRunner
This add on allows you to add very powerful configurations and scripting to your instance. You do need groovy experience to use this but its definitely an add on I recommend having.
Hi @Cody Stevens ,
Thank you so much for providing me those options. I will try those add-ons you mentioned.
Shahriar
Of course, I am glad I could help!
Read the story
