×Are there any special considerations I need to be aware of?
Hey,
For Confluence is a little different. You can check in our documentation on how to achieve it:
https://confluence.atlassian.com/display/DOC/Migrating+Confluence+Between+Servers
I hope this helps.
WZ
Basically is the same thing as moving JIRA from a server to another. JIRA is compatible with both, Linux and Solaris, and you can follow the documentation below:
- https://confluence.atlassian.com/display/JIRA/Migrating+JIRA+to+Another+Server
Best regards,
Lucas Timm
Thanks, all for the answers. I admit to not being sure that this is how I'm supposed to accept an answer
