Hello I am using Jira JIRA 4.3.4
How do i remove links from the left panel and from Activity when clicking on Projects Tab
there is the following links:
Summary
Issues
Popular Issues
Labels
Source
Reviews
I would like to customized the links (remove Source link,remove Reviews)
I just want to show Summary ,Issues Popular Issues and remove Labels,Source,Reviews
Thanks for any help
Disable the FishEye Issue Tab Panel and Crucible Issue Tab Panel as well. You should apply some logc sometimes!
hahaha you are right I should apply not sometimes but always
Disable the crucible and fisheye project panels under Admin -> Plugins. You will lose functionality, but if you're not using those systems, it's not a problem.
Excellent man ) keep going on! ...
I like this post better than your previous answers )
It is still can be found here in the Activity section
http://i51.tinypic.com/sb7bsi.png
Please see the answer for https://answers.atlassian.com/questions/2660/how-to-remove-source-and-reviews-page-link
It works fine but I can still see both Source and Reviews in the Activity
please double check so i can mark this issue as solved
These two panels come from the Fisheye plugin. If you just want to disable the panels alone, follow the steps:
You can disable the entire plugin if you don't use it at all!
Right, that was too late :)
I attached a snapshot http://i51.tinypic.com/sb7bsi.png</p<>>
