Entering a url, or running with curl, like:
https://<myurl>/rest/api/2/search?jql=project=<myproject>&status=closed&fields=id,key,status,project&maxResults=5
returns me 5 items in my project but with all statuses. For some reason I can't query for a specific status.
The output (part of it) is:
{ "expand": "schema,names", "startAt": 0, "maxResults": 5, "total": 727, "issues": [ { "expand": "editmeta,renderedFields,transitions,changelog,operations", "id": "79577", "self": "https://<myurl>/rest/api/2/issue/79577", "key": "<myproject>-774", "fields": { "project": { "self": "https://<myurl>/rest/api/2/project/<myproject>", "id": "14421", "key": "<myproject>", "name": "<myproject>", "avatarUrls": { (...) } }, "status": { "self": "<myurl>/rest/api/2/status/1", "description": "The issue is open and ready for the assignee to start work on it.", "iconUrl": "https://<myurl>/images/icons/statuses/open.png", "name": "Open", "id": "1" } } },(...) ] }
How to query for a given status? Many thanks.
Your parentheses need to be properly encoded:
( = %28
) = %29
An easy way to get the proper encoding is to
5,5 years later but still... Great tip!
7 years 8 months later and still a great tip, thank you!
YES! Finally got it working, thank you!!
$url = 'https://<oururl>.jira.com/rest/api/2/search?jql=project%20%3D%20<ourteam>%20AND%20status%20in%20(%22In%20Analysis%22%2C%20%22In%20Development%22)%20ORDER%20BY%20priority%20DESC%2C%20status%20DESC&fields%3Did,key,summary,priority,status,project,assignee';
Thank you, this helped a lot!
JQL for statuses:
status in (resolved)
In your example
https://<myurl>/rest/api/2/search?jql=project IN (<myproject>) AND status in (resolved)&fields=id,key,status,project&maxResults=5
Please, don't use "=" in URLs variables. Change them to %3D or use "IN". You can use URLencode to get rid of them.
https://<myurl>/rest/api/2/search?jql=project%3D<myproject>%20AND%20status%3Dresolved&fields=id,key,status,project&maxResults=5
When you search for issue in JIRA's Issue Browser, you can click "Advanced" link, to show current query as JQL.
ProszÄ™ bardzo :)
@Tomasz Rykala , is the 'jira.com' bit necessary?
Still doesn't help. My items are always sorted by ID descending.
Current query:
$url = 'https://<oursite>.jira.com/rest/api/2/search?jql=project%3D' . $TEAM . '%20AND%20status%20IN%20(%22in%20analysis%22,%22in%20development%22)&fields%3Did,key,summary,priority,status,project,assignee%20ORDER%20BY%20priority,status%20asc'
Did you ever get this working? I'm having trouble getting the orderBy setting to work properly...
@John D_ Lewis The "current query" example in the question you are asking about has field parameters in the middle of the JQL parameter, so it isn't going to work regardless of how you set up the order by clause in the JQL. Do you have an example you are working with that you want to post?
I was able to get this query to work (from a nodejs app): "https://" + user + ":" + token + "@site-name-here.atlassian.net/rest/api/latest/search?jql=project='project-name-here' ORDER BY 'key'&maxResults=100" - took me a while to get the single-quotes and spaces working properly, but now it's ironed out (and looks so simple!)
Hi, could you help me with this please? I can't get my results to sort.
...&fields=id,key,summary,priority,status,project,assignee%20order%20by%20priority%20asc
doesn't sort my results by priosity in ascending order for example
Help us plant more trees
