×This code is really heavy handed to update the fixversion field. I looked up and found Issue.setFixVersions([V]); approach. Is this deprecated?
Its a lot cleaner than the above answer but does not seem to work.
It's not saved your way.
Currently I would suggest to use IssueService.update(), a minimal version would be like this:
issueService = ComponentAccessor.issueService
def iip = issueService.newIssueInputParameters()
iip.setFixVersionIds(version.id)
def valRes = issueService.validateUpdate(user, issue.id, iip)
if (valRes.isValid()) {
issueService.update(user, valRes)
Of course this is without error handling etc.
Best regards,
Henning
