×I wanted to change my attachment directory to use a NAS folder for disaster recovery backup. however, when I go into the attachments page and click 'Edit Settings' it does not let me change it from use default directory? Is it possible to change the attachment folder to use a NAS?
Hi Joanne,
you could define a new JIRA_HOME -> please read this before! Then all of your JIRA-Data is saved on NAS.
Please do on your own risk! This would be the steps i'd do:
jira-application.properties
to point on \\NAS\JIRA-HOME and saveIf it fails: Shut down again and point back to the old JIRA-HOME in jira-application.properties
. Should again start just fine.
Cheers, Mario
Can you tell me more about your environment?
Are you running under Linux or Windows? If you are working in a Linux world, you can use mount points at the operating system layer and avoid reconfiguring the application.
(FWIW: This is what I do on the Atlassian Support JIRA instance. Dealing with storage at the operating system layer is just easier.)
