How do I split SQL output into separate lines via Scriptrunner?
Michael Krüger November 25, 2022
Hi all,
I'm trying to run sql query to get all users who have never been logged in to JIRA via Scriptrunner console.
import com.onresolve.scriptrunner.db.DatabaseUtil
import groovy.sql.Sql
def issueManager = ComponentAccessor.issueManager
def output = []
DatabaseUtil.withSql('local') { sql ->
output = sql.rows("SELECT cwd_user.id, cwd_user.user_name, cwd_user.created_date FROM jiradb.cwd_user WHERE not exists (select cwd_user_attributes.user_id from jiradb.cwd_user_attributes where cwd_user_attributes.attribute_name = 'login.count' and cwd_user_attributes.user_id = cwd_user.id) and cwd_user.active = true order by cwd_user.created_date")
log.warn "${output.size()}"
log.warn "${output}"
output
I got a result, but it's one large string separated by comma.
I want to have the output line by line (1 line per user id), but everything I try fails.
Thx,
Michael
Vikrant Yadav
November 25, 2022 edited
Hi @Michael Krüger Welcome to Atlassian Community!
Try to modify your result part like below script, to get the Result in table format :-
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def delegator = (DelegatorInterface) ComponentAccessor.getComponent(DelegatorInterface)
String helperName = delegator.getGroupHelperName("default")
//Update SQL query as per the your requirement
def sqlStmt = """
SELECT cwd_user.id, cwd_user.user_name, cwd_user.created_date FROM cwd_user
Connection conn = ConnectionFactory.getConnection(helperName)
Sql sql = new Sql(conn)
//Create table
String result = """
<table>
  <tr>
    <th>UserId</th>
    <th>User Name</th>
    <th>Create Date</th>
  </tr>
sql.eachRow(sqlStmt){ it ->
    result += """
        <tr>
          <td>${it.getAt("id")}</td>
          <td>${it.getAt("user_name")}</td>
          <td>${it.getAt("created_date")}</td>
        </tr>
return result+"</table>"
sql.close()
Vikrant Yadav
@Michael Krüger  If SQL query doesn't works for you then try to run script mentioned in below link in script console :-
https://gist.github.com/vikrantyadav11/61a04c6f05a8fb719e773ab42b1b5b67
Michael Krüger November 28, 2022 edited
Hi @Vikrant Yadav
thanks a lot for your quick response.
Sounds interesting with the table creation (I'll try that also), but I simply want to have the result line by line without any further formatting.
This is how the result looks like now:
After each closing square bracket a line break should be done.
Thx,
Michael
Like Vikrant Yadav likes this
Vikrant Yadav
@Michael Krüger
Try below script for this , use :- sb.append('\n')
But it give only result upto 300 lines only.
Update SQL query as well and column name cfname.
def sqlStmt = """
SELECT cfname
FROM customfield
WHERE customfieldtypekey = 'com.atlassian.jira.plugin.system.customfieldtypes:select';
try {
StringBuffer sb = new StringBuffer()
sql.eachRow(sqlStmt) { it ->
sb.append( it.getAt("cfname") )
sb.append('\n')
log.warn sb.toString()
finally {
sql.close()
V.Y
Michael Krüger November 29, 2022
Hi @Vikrant Yadav
that works for me. Thanks a lot.
Best,
Michael
Register today
