×JIRA is installed on a server with no public domain name, so the problem would be to connect from Bitbucket to JIRA. Could I set up JIRA to syncronize on a specified time interval ?
Same issue for GitHub users as discussed here:
https://answers.atlassian.com/questions/57829/setup-dvcs-force-sync-as-a-service
A newer version of JIRA (5.1.3) helps with this issue and it is no longer a problem.!
Thanks Norman for your effort and time.. I was hoping for an easier solution, for now it is cheaper for us to go into JIRA and press Force sync rather than implementing this.
I was attempting to look up the steps but I think the connector documentation may be sufficient.
Ideally you want
loop
get log information since the last time you got log information
update jira with the log information
end
record the last update to be used as the start time.
So
I can see two approaches.
clone the repository on your private network
install the dvcs connector on the clone repository
Now update a file in a different repository, commit and push
now do a pull operation on the newly cloned repository
Now see if Jira was updated.
The other approach is
build a separate java application based upon the dvcs plugin code that updates Jira. This gives you the all the calls necessary to update Jira. Lets say this application reads a file.
Now use the bit bucket command to get log information and format the results to be input to your jira update program.
Now you can build a script that pulls from bitbucket, creates the log input file and then updates jira.
Ok .. i am willing to try .. do you have any links or guides how to do it ?
Since you are willing to code, the subversion plugin does a pull operation from the jira side based upon a time interval. This gives you a framework for the service. You then integrate/code the DVCS plugin code that updates Jira into subversion service and then change the subversion code that pulls the history information to use the bitbucket commands for log history.
I am not using Subversion but HG Mercurial, so i do not think it is an option.
My internet connection went out. You are replacing the subversion code with the bitbucket/mercurial code.
It is not another link in the chain, it is more like another developer and that developer is Jira.
Are you willing to do some medium level of coding? If not, then the shadow repository mentioned in the referenced question should work for you.
Im willing to do som medium coding .. but where do i start?
The shadow repository seems a bit overkill .. the reason for using Bitbucket is that it is outside our firewall .. and bringing in another link in the chain with shadow repository is not an option.
