Hi
I am running Jira Server v7.3.8
I am trying to write a custom rest end point that will set a custom fields value on an issue.
Here is my current code...
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.config.PriorityManager
import com.atlassian.jira.issue.fields.rest.json.beans.JiraBaseUrls
import com.atlassian.jira.issue.fields.rest.json.beans.PriorityJsonBean
import com.atlassian.jira.issue.index.IssueIndexingService
import com.atlassian.jira.issue.index.IndexException
import com.atlassian.jira.issue.index.IssueIndexingParams
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import groovy.transform.BaseScript
import org.codehaus.jackson.map.ObjectMapper
import groovy.json.JsonBuilder
import com.atlassian.jira.util.ImportUtils
import javax.ws.rs.core.MultivaluedMap
import javax.ws.rs.core.Response
import javax.ws.rs.core.Response.Status
log.setLevel(org.apache.log4j.Level.DEBUG)
@BaseScript CustomEndpointDelegate delegate
update_cf(
httpMethod: "PUT", groups: ["jira-administrators","automation"]
MultivaluedMap queryParams, String body ->
def mapper = new ObjectMapper()
log.debug("Body Start \n " + body + "\n Body End")
def bean = mapper.readValue(body.getBytes(), Data)
assert bean.issueKey // must provide issue key
assert bean.customFieldID // must provide custom field ID
assert bean.value // must provide value
def im = ComponentAccessor.getIssueManager()
MutableIssue issue = im.getIssueObject(bean.issueKey)
if(issue == null){
return Response.serverError().entity([error: "Failed to Find issue with key ${bean.issueKey}"]).build()
log.debug("key : ${issue.getKey()}")
def cfm = ComponentAccessor.getCustomFieldManager()
def customField = cfm.getCustomFieldObject(bean.customFieldID)
if(customField == null){
return Response.status(Response.Status.BAD_REQUEST).build()
log.debug("CF : ${customField.getName()}")
log.debug("CF val : ${issue.getCustomFieldValue(customField)}")
issue.setCustomFieldValue(customField,bean.value)
IssueIndexingService issueIndexingService = ComponentAccessor.getComponent(IssueIndexingService.class)
if(issueIndexingService == null){
log.error("IssueIndexingService = null")
return Response.serverError().entity([error: "Failed to update index. Please notify a Jira Administrator"]).build()
log.debug("Starting try//catch")
log.debug(issue.getCustomFieldValue(customField))
try{
log.debug("starting reindex")
issueIndexingService.reIndex(issue);
log.debug("Issue should be reindexed")
log.debug("issue CF val : ${issue.getCustomFieldValue(customField)}")
}catch(Exception e){
log.error("Failed to Reindex")
return Response.serverError().entity([error: e.getMessage()]).build()
}finally{
log.debug("in Finally")
log.debug("Afer try//catch")
return Response.ok(new JsonBuilder(["package": bean]).toString()).build()
public class Data {
String customFieldID
String value
String issueKey
Here is the log output......
2018-11-13 11:59:49,080 DEBUG [runner.ScriptRunnerImpl]: Body Start { "customFieldID" : "customfield_15446", "value" : "Yay it works", "issueKey" : "PSG-406792" } Body End 2018-11-13 11:59:49,087 DEBUG [runner.ScriptRunnerImpl]: key : PSG-406792 2018-11-13 11:59:49,087 DEBUG [runner.ScriptRunnerImpl]: CF : Last Name 2018-11-13 11:59:49,088 DEBUG [runner.ScriptRunnerImpl]: CF val : Maharaj 2018-11-13 11:59:49,088 DEBUG [runner.ScriptRunnerImpl]: Starting try//catch 2018-11-13 11:59:49,088 DEBUG [runner.ScriptRunnerImpl]: Yay it works 2018-11-13 11:59:49,088 DEBUG [runner.ScriptRunnerImpl]: starting reindex
response code = 200
body
"package": {
"value": "Yay it works",
"customFieldID": "customfield_15446",
"issueKey": "PSG-406792"
My confusion lies in that the code seems to stop running once it gets to the reindex part.
no exceptions, no finally, nothing after....
When I go to the issue the custom field also has not been updated.
The field is on the edit screen.
The user I am using to authenticate has permission to edit the issue.
Please can some one help
Try to use "updateValue" instead of setCustomFieldValue and use "updateIssue" instead of reindex.
Example of updateValue:
customField.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(customField), customField,bean.value),new DefaultIssueChangeHolder());
Example of updateIssue:
im.updateIssue(user, (MutableIssue) issue, EventDispatchOption.ISSUE_UPDATED, false);
How to run this Rest API ?
