How do I upload attachment to JIRA Issue via REST API(Oracle)?
Алексей Васильевич Ващенко
March 12, 2019
Does not work. Help.
procedure P_SendAtachToJira(p_issue_id varchar2, p_sd_id number)  is
http_resp utl_http.resp;
http_req utl_http.req;
v_file_body blob;
v_file_name varchar(200);
req_length number;
v_buffer raw(32767);
offset number;
amount number;
begin
-- dbms_output.put_line(v_json_main.to_char);
http_req := utl_http.begin_request('http://help-pc.mc.gcf:8080/rest/api/2/issue/' || p_issue_id || '/attachments', 'POST',' HTTP/1.1');
UTL_HTTP.SET_AUTHENTICATION(http_req, c_name, c_password);
utl_http.set_header(http_req, 'X-Atlassian-Token', 'no-check');
utl_http.set_header(http_req, 'Content-Type', 'application/vnd.ms-excel');
utl_http.set_header(http_req, 'user_agent', 'File Upload Agent');
-- utl_http.set_header(http_req, 'content-type', 'application/octet-stream');
select t.sd_file_body, t.sd_file_name into v_file_body, v_file_name
from SERVICEDESK_OWNER.TBL_SD_FILES t where t.sd_file_id = 736014;
req_length := dbms_lob.getlength(v_file_body);
utl_http.set_header(http_req, 'content-disposition', 'attachment; filename="' || v_file_name || '"');
utl_http.set_header(http_req, 'Content-Length', req_length);
offset := 1;
amount := 32767;
if req_length <= 32767 then
utl_http.write_raw(http_req, v_file_body);
elsif req_length >32767 then
utl_http.set_header(http_req, 'Transfer-Encoding', 'Chunked');
while (offset < req_length)
loop
dbms_lob.read(v_file_body, amount, offset, v_buffer);
utl_http.write_raw(http_req, v_buffer);
offset := offset + amount;
end loop;
end if;
http_resp := UTL_HTTP.get_response(http_req);
dbms_output.put_line(to_char(http_resp.status_code));
-- process the response from the HTTP call
end;
Ravi
March 12, 2019
Learn more
