How do Tempo and Jira's Work Log correlates?
Ronen Ahuvia January 26, 2013
We have worklog enteries in Jira's work log.
We wan't to install and use Tempo. 2 questions:
1. Will Tempo timesheet display work that was logged in Jira previously?
2. Do we have to turn off Jira's work log? Should it remain enabled?
Ronen.
shampa
January 27, 2013
1. Tempo timesheets will display JIRA work logs entered previuosly
2. YOu shoudl turn off JIRA work log function so as to make use of rules configured in Tempo like not allowing more than 24 hours of work log in a day etc.
Ronen Ahuvia January 27, 2013
Thanks for the answer.
Turning off work log function in Jira will create a problem: we have a "Resolved issue" screen in which the developer updates how he handled the issue. Among other things, he's updating his working time on the issue.
I can't find fields of Tempo which can replace Jira's fields and can be part of issue resolution screen.
Am I wrong?
Thanks.
Viðar Svansson [Tempo]
January 27, 2013
You are correct. But you might want to disable the Log Work link the the issue actions and operations section.
Joe F. Lee February 4, 2013
@ Viðar [TEMPO]
How do I disable the Work Log link in the issue actions and operations section without turning off the Jira work log function all together?
February 4, 2013
Javier González Jiménez July 3, 2014
Nota that you can not disable the JIRA worklog con Jira On Demand.
Aditya Wirayudha
October 27, 2013
shampa
January 27, 2013
Help us plant more trees
