How do escape "}" character?
Steve Kuo
I'm trying to make the following text as monospace in JIRA
/foo/{bar}
According to the WikiRendererHelpAction page, I should wrap my text in {{}}. Ok so now I have:
{{/foo/{bar}}}
Unfortunately this doesn work. I get
{{/foo
{bar}
So I try escaping the last "}" as "\}".
{{/foo/{bar\}}}
This almost works, all but the last "}" is monospace. I also tried escaping both { and }
{{/foo/\{bar\}}}
But this has the same results - the last "}" is not monospaced. Is there a way to make all of /foo/{bar} monospace, or is this a JIRA bug?
Peter Van de Voorde
May 7, 2014
hi Steve
you could try something like this :
{{*/foo/\{bar\}*}}
It seems to only work correctly when there is at least one more character behind the escaped "}".
I would report it as a bug in https://jira.atlassian.com
Best regards,
Peter
Steve Kuo
Like Allen Barnard likes this
