×For example. I created a custom field and selected the Cascading Select List from the Field Type list. This type allows for 2 select fields.
I then added options for the first select field, but i dont see where to add options for the second select field.
Where do i add options for the second select column?
Click "configure" to the right of the option you want to add the sub-options to.
thank you. I have to do this individually for each option in column 1?
Yes, I'm afraid so.
