How do i change catalina.out timeformat.
Magnus Tamm November 25, 2019
Hi. I have two problems.
1) My catalina.out writes different timestamps. Can I fix it and if I can then how? (both formats are wrong.
         1.  Nov 25, 2019 10:22:09 AM
         2.  2019-11-25 09:32:23,326
And the second question is that how do I make them look like this? How do I change my timeformat for catalina.out
I need. 2019-11-25T10:24:46.292+0200 - (yyyy-MM-dd'T'HH:mm:ss.SSSZ)
2 accepted
Vickey Palzor Lepcha
November 25, 2019
JIRA logs are based on log4j.properties files. You will have to make changes in log4j files for any changes in logs.
Yes. Time format is described as %d but how do I modify it?
Fixed this part
2.  2019-11-25 09:32:23,326 now it writes like it should but
1.  Nov 25, 2019 10:22:09 AM can't find solution for this
Magnus Tamm November 26, 2019
Okay. I will answer myself :D
First part i changed was at log4j.properties
changed %d to %d{yyyy-MM-dd'T'HH:mm:ss.SSSZ}
Second part I changed at jre/lib/logging.propperties
I commented this line out and changed its values
java.util.logging.SimpleFormatter.format=%1$tY-%1$tm-%1$tdT%1$tH:%1$tM:%1$tS:%1$tL%1$tz %2$s%n%4$s: %5$s%6$s%n
I also modified conf/logging.properties.
added.
# formatter attributes = date, source, logger, level, message, thrown
java.util.logging.SimpleFormatter.format = %1$tY-%1$tm-%1$tdT%1$tH:%1$tM:%1$tS:%1$tL%1$tz %2$s%n%4$s: %5$s%6$s%n
and
1catalina.org.apache.juli.AsyncFileHandler.formatter = java.util.logging.SimpleFormatter.
now it's okay
Vladimir December 11, 2020
oh, so much action) you can also concatenate into one line:
edit /apache-tomcat/conf/logging.properties (for JIRA: \JIRA DIR\conf\logging.properties)
1catalina.java.util.logging.SimpleFormatter.format=<your format>
e.g.
1catalina.java.util.logging.SimpleFormatter.format= %1$tY-%1$tm-%1$tdT%1$tH:%1$tM:%1$tS:%1$tL%1$tz %2$s%n%4$s: %5$s%6$s%n
p.s.
for tune I use manuals:
Java Formatter in English
Java Formatter in Russian
Vladimir December 10, 2020
Excellent! It really works!
