I guess this is for Manually added Custom Fields, how to check Id for default system fields?
Custom fields have numerical id's whereas the system default fields all have names (tends to be a 1:1 ie assignee = assignee).
This link lists them;
Thanks for the reply, what I'm trying is when I create an issue I have the two fields due date(system field) and priority(select list drop-down), I need to auto-populate the due date field to today's date when I select any of the select list in the priority field. do you have any idea on this to help?
This isn't possible with a standard Jira setup. You can only change fields with post functions and not based off the value of another field. I don't know if any add-ons such as script runner would be able to do this
