How do i upload an attachment to Jira ticket using rest api , using .js ?
Praveen Nulu
November 13, 2018
I need to use Rest API to upload some of our automated runs result reports to Jira tickets using nightwatch java script.
Can any one help me fix the 415 response i am getting using the below code :
'Jira: Add Attachment': function (browser) {
//const jira = browser.page.jira();
var request = require('request');
var options = {
method: 'POST',
url: 'https://provinnovate.atlassian.net/rest/api/3/issue/TOQ-633/attachments',
file: {
'file': '/Users/praveennulu/Documents/Github/IntegratedScheduling-master/test_e2e/reports/TestDoc.pdf'
headers: {
'Authorization': 'Basic cHJhdmVlbi5udWx1QHByb3ZpZGVuY2Uub3JnOjJ4Nm55WjFpMFdhWFRQRHdKbWJMMDE0Ng==',
'Accept': 'application/json',
'Content-Type': 'application/octet-stream',
'X-Atlassian-Token': 'no-check',
request(options, function (error, response, body) {
if (error) throw new Error(error);
console.log(
'Response: ' + response.statusCode + ' ' + response.statusMessage
console.log(body);
Andy Heinzer
November 14, 2018
Hi Praveen,
The 415 error code is an indication that your REST call is using the incorrect 'Content-type' header for the file you are trying to upload to Jira.  This is explained in more detail in a related Fisheye KB REST API: "Error 415 Unsupported Media Type".  I realize that KB is geared for a different product than your Jira Cloud, but the concept is the same here in terms of file attachments via REST.
Instead of using the header of
I think instead this should be something like
'Content-Type': 'application/pdf'
for this particular pdf file.
I hope this helps.
Andy
Praveen Nulu
November 14, 2018
Even that is also giving me the same 415 response code.
The reason for adding the Content-Type: 'application/octet-stream' was due to the below  500 error i was getting when i don't use any  Content-Type .
Response: 500
{"message":"org.apache.commons.fileupload.FileUploadBase$InvalidContentTypeException: the request doesn't contain a multipart/form-data or multipart/mixed stream, content type header is application/octet-stream","status-code":500,"stack-trace":"java.lang.RuntimeException: org.apache.commons.fileupload.FileUploadBase$InvalidContentTypeException: the request doesn't contain a multipart/form-data or multipart/mixed stream, content type header is application/octet-stream\n\tat com.atlassian.plugins.rest.common.multipart.fileupload
Andy Heinzer
November 19, 2018
Hi Praveen,
It looks like I was mistaken in my last reply.  Sorry about that.
You don't actually need to define the content-type when uploading a file via the REST API.   I tested this myself using curl and the syntax of
curl --request POST \
  --url 'https://example.atlassian.net/rest/api/3/issue/SCRUM-12/attachments' \
  --header 'Authorization: Basic {myAPItokenhere}' \
  --header 'Accept: application/json' \
  --header 'X-Atlassian-Token: nocheck' \
  -F "file=@/path/to/file/12345.pdf"
I think that you're getting this error because you are trying to define the content-type here when in fact the documentation on using this endpoint does not indicate to use that specific header.  More details in Add attachment POST /rest/api/3/issue/{issueIdOrKey}/attachments.
I believe you should be able to make this work in your python by just removing the 'Content-Type' header entirely.
I hope this helps, please let me know the results.
Andy
Like • Rigo likes this
LostInMadness Forever December 2, 2019
if you don't define the content'type u got a 500 status error code........
Like • Robert McCool likes this
Nikhil Singh
October 23, 2023
Hi @Praveen Nulu ,
Did you get the answer to this? I am also facing the same issue.
I have added Headers as
1. Content-type: application/json
2. X-Atlassian-Token: nocheck
I have not added
file: {
but I am adding payload as this
    "attachment": [
            "content_type""image/png",
            "file_name""postman.png",
            "size_bytes""1124594",
            "sys_id""afcbf3e1474ab5104b5b9e79e16d4398",
            "Content-Transfer-Encoding""iVBORw0KGgoAAAANSUhEUgAACGgAAAX0CAYAAACfQ617AAAMP2lDQ1BJQ0MgUHJvZmlsZQAASImVVwdYU8kWnluSkEBCCV1K6E0QqQGkhNACSO"
