How do you add test cases into already created Test Plans?
Chris Foronda January 8, 2015
We are using SynapseRT.
When I create a Test Plan and I have already added Test Cases and SubTask to the Test Plan. When I want to edit the Test Plan to add more Test Cases or SubTask in the Test Case Field it says:
To edit test plan, press on button Stop Test Plan.
Custom field for Go2Group Test Case custom field type
But there is no "Stop" button.
I created some Test Plans and there are no Test Cases within it, so I want to edit now and place some test cases and subtask.
Can some help with this?
jb
January 9, 2015
Hello Chris,
On Monday, January 12th, new release of synapseRT will be available for installation. Please check this version, the problem is no longer present in this version.
Best Regards,
Alex.
Chris Foronda January 12, 2015
Thank you Alex
Ok thank you Boris.
Boris Berenberg
January 8, 2015
I don't know the answer to this, but I did want to get the right addon tag on this question in hopes of bringing the right people here to help.
SynapseRT. We are thinking about about trying out Jira Capture (Bonfire)
Boris Berenberg
January 8, 2015
What plugin are you using for test case management?
