×Say you have an issue and it's sub-tasks resolved/closed. You then need to re-open the sub-task, is there a way to open the parent issue when a sub-task is re-opened?
I've created a plugin with several workflow plugins for subtasks.
https://bitbucket.org/mbrizi/jira-plugins/raw/908616ebe2bc/ugov-jira-subtask-plugin/target/ugov-jira-subtask-plugin-1.4.2.jar
<label for="it.cineca.jira.plugin.ugov-jira-subtask-plugin:transitionparentissue-function"></label>
You can use the "Transition Parent Issue Function" and specify the transition id for the parent issue workflow.
I hope it helps.
There are already a number of plugins to help you do that:
https://plugins.atlassian.com/search/with?q=scripting&product=all
Eva Lee is right, but they will spare you to dig too much in JIRA.
The only way I can think of at the moment is to create a post-function plugin where it reopen the main task for you, similar to the existing post-function where it close teh parent when the subtask is closed. I dont think you can do it any other way than customize plugin
