How do you do a search with contains and multiple fields?
Christine Ritchie July 13, 2018
This works
 project = APT AND FreeForm ~ NIRCAM AND FreeForm ~ "IMS=True" ORDER BY issue DESC
   This didn't work
   project = APT AND FreeForm ~ (NIRCAM AND "IMS=True") ORDER BY issue DESC
Looks like this does it!
project = APT AND FreeForm  ~ "NIRCAM IMS=True"
Tyler Brown
July 13, 2018
Hey Christine,
Instead of AND in your brackets have you tried using a "," to separate your values?
Tyler
I hadn't but none of these work
project = APT AND FreeForm ~ (NIRCAM,"IMS=True") ORDER BY issue DESC
Operator '~' does not support the list value '("NIRCAM", "IMS=True")' for field 'FreeForm'.
project = APT AND FreeForm ~ NIRCAM,"IMS=True" ORDER BY issue DESC
didn't complain but didn't find anything whereas the more klunky search finds issues.
Tyler Brown
July 13, 2018
Can you try FreeFrom in (NIRCAM, "IMS=True")
Got back
The operator 'in' is not supported by the 'FreeForm' field.
is doesn't seem to work either
project = APT AND FreeForm is ("NIRCAM", "IMS=True")
Got back
  • Operator 'is' does not support searching for non-empty values for field 'FreeForm'.
  • Operator 'is' does not support the list value '("NIRCAM", "IMS=True")' for field 'FreeForm'.
I just thought it could be neatened up ... but perhaps not.
I can get multiple fields with
project = APT AND FreeForm  ~ "NIRCAM IMS True"
but unfortunately this isn't IMS=True and there are other True options in the Freeform Field.
