How do you restrict the ability to create labels to a specific group of users?
Logan G Hawkes
March 27, 2012
I have a large number of test cases in Jira that are tagged with various labels. Many of the labels are redundant, as they are either the same word misspelled (Acceptance, Acceptence, Accepence, Aceptance, Aceptence) or a variation on another label (collector, collectors, datacollectors, data_collector). I'd like to restrict the ability to create new labels to a specific user or set of users, but there doesn't seem to be a way to do it.
So far the best solution I've come up with is to create a set of "correct" labels and hope that people will use the auto-suggested label. This has not proved successful. Today I found that a user has been labeling test cases with the IP of the server used for testing (as opposed to the "Test Environment" field). Just to add to the fun, she used commas instead of decimal points at random: "172.17,10,1", "172,17.10,1", etc.
Does anyone have any ideas for imposing order on the situation?
Abraham Collier (US - Advisory)
November 22, 2016
@Renjith Pillai, if you're still on here, I'm not sure I understand your answer here or below. Do you know if Atlassian has come up with any way to allow administrators to limit the number and/or names of labels within an enterprise's Confluence pages?
ALO
I have the same issue with label-type fields and am looking for a possibility of restricting it to the project role. So far no idea how.
Any ideas? Thank you for the help!
Renjith Pillai
February 2, 2013
Thoughts:
  1. Create a transition for your workflows (global) which says 'Change Labels' and protect that transition only the project role. Use a screen which has just the label field.
  2. Created a scripted field that shows the values from the label field so that you can use that in the View issue screen and remove the actual label field from the View issue screen.
ALO
Thank you Renjith for your suggestions.
I'm not quite sure what do you mean by "a scripted field that shows the values from the label field". How can I create such a field? You mean to be able to just see the label field on the View issue screen, but only static, so that nobody else can edit it...?
Many thanks!
Loredana
Renjith Pillai
February 4, 2013
Sorry missed to add the link in the previous comment. The scripted field comes from Jamie - https://jamieechlin.atlassian.net/wiki/display/GRV/Script+Runner
Martin von Arx May 26, 2014
I have done the 2 steps you have described on Feb 03 '13.
But now I have the problem to write the correct script to show the contents of the label field on a transition. So that the jira-users can choose several items of the list and add to an issue.
How do I have to write that script?
Regards
Martin
Logan G Hawkes
March 27, 2012
Sadly, I'm trying to avoid using a multi-select, as I need a large set of identifying tags. I've been trying out the MDSF plugin so I can use more than two levels of cascading selects, but it has its own limitations.
Renjith Pillai
March 27, 2012
Labels are something which is usually left to the discretion of the users to decide the right content. But if you need to restrict, may be just you a Multi Select custom field and call it Labels.
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
