Hello,I have the following problem:
I created an objecttype which has a text attribute called Supplier.
I created an automation rule that sends an email.
the body of the email rule is:
id object: ${objectId}
key: ${Key}
Supplier:${Supplier}
the result is:
id object: 9725
key: SSC-9725
Supplier:
why is the Supplier attribute not printed? I also tried with other attributes i defined and none are printed, only blank value is returned.
the Insight placeholder not working with user-defined attributes?
is there a solution or am I wrong something?
my insight version is 8.7.7
If Supplier is an array, you can try ${Supplier${0}}.
The supplier that is stored in the current object will be taken.
