Hi, the client has requested a custom field, but when i run a script the result is null. Dont detect the custom field, only detect the one that comes by default in JIRA.
Im usign ScriptRunning wiht groovy code.
Any have idea?
Thanks a lot.
Hi @Andres BS if you want to know the custom field ID
Admin settings > Issues > Left hand side pannel select Custom field It will list all the custom fields that are created > Find the custom field that you want
and there is a setting icon on right side of each field click it and choose "configure" so on the Browser Url end it will show you the "ID" of that Field
Example: customFieldId=10020
Kumar
Register now
