How get value from text field?
daymonTwo February 8, 2020 edited
Hi, i want get value from text field and set value in other field but in log i see error
2020-02-08 21:57:22,402 http-8080-5 ERROR admin 1377x821x1 ljf71i 127.0.0.1 /rest/com.onresolve.jira.plugin.Behaviours/1.0/behaviours/runvalidator.json [onresolve.jira.groovy.BehaviourManagerImpl] Something went wrong with method run in class
java.lang.NumberFormatException: For input string: "MYF-1"
This is my code
def cutomField=getFieldById("customfield_10000");
String value=(String)cutomField.getValue();
def sum=getFieldById("summary");
sum.setFormValue(value);
maybe someone write how get rid of this error. Thanks
Version my jira 5.0.3
daymonTwo February 9, 2020 edited
If I write this, then everything works fine
String value=(String)cutomField.getFormValue();
Kaushik Veluru
February 8, 2020
Am not sure what fields you are updating. But from the error it shows that the field is supposed to be Number but you are entering a string.
If "MYF-1" is an issue, get issue ID and use that.
Thomas Deiler
Dear @daymonTwo ,
it seems that you question is better placed at https://community.developer.atlassian.com/.
Could you be so kind to reopen it there?
So long
Thomas
Register now
