×Hello
Guys, how to include file attachments from a task when creating a page in this script?
import com.atlassian.applinks.api.ApplicationLink
import com.atlassian.applinks.api.ApplicationLinkService
import com.atlassian.applinks.api.application.confluence.ConfluenceApplicationType
import com.atlassian.sal.api.component.ComponentLocator
import com.atlassian.sal.api.net.Request
import com.atlassian.sal.api.net.Response
import com.atlassian.sal.api.net.ResponseException
import com.atlassian.sal.api.net.ResponseHandler
import com.atlassian.jira.issue.AttachmentManager
import groovy.json.JsonBuilder
import groovy.json.JsonSlurper
AttachmentManager attachmentManager = ComponentAccessor.getAttachmentManager()
def ApplicationLink getPrimaryConfluenceLink() {
def applicationLinkService = ComponentLocator.getComponent(ApplicationLinkService.class)
final ApplicationLink conflLink = applicationLinkService.getPrimaryApplicationLink(ConfluenceApplicationType.class)
conflLink
// the issue provided to us in the binding
def issue = ComponentAccessor.issueManager.getIssueByCurrentKey("TESTCASE-17")
//Issue issue = issue
//if (!issue.issueTypeObject.name == "Bug") {
//return
def confluenceLink = getPrimaryConfluenceLink()
assert confluenceLink
def authenticatedRequestFactory = confluenceLink.createImpersonatingAuthenticatedRequestFactory()
def pageTitle = issue.key + " Discussion"
def pageBody = """h3. ${issue.summary + issue.attachement}
{quote}${issue.description}{quote}
Yada yada, use this page to discuss the above...
def params = [
type : "page",
title: pageTitle,
space: [
key: "TESTSR" // set the space key - or calculate it from the project or something
/* // if you want to specify create the page under another, do it like this:
ancestors: [
type: "page",
body : [
storage: [
value : pageBody,
representation: "wiki"
.createRequest(Request.MethodType.POST, "rest/api/content")
.addHeader("Content-Type", "application/json")
.setRequestBody(new JsonBuilder(params).toString())
.execute(new ResponseHandler<Response>() {
@Override
void handle(Response response) throws ResponseException {
if (response.statusCode != HttpURLConnection.HTTP_OK) {
throw new Exception(response.getResponseBodyAsString())
} else {
def webUrl = new JsonSlurper().parseText(response.responseBodyAsString)["_links"]["webui"]
Heya, @[deleted]! So, you won't be able to simply inline the attachments into the Confluence page body from the issue.attachments API.
You will probably need to do a separate request to create the attachments after the page is created. Atlassian have some documentation on using the Confluence REST API to create attachments at https://confluence.atlassian.com/confkb/using-the-confluence-rest-api-to-upload-an-attachment-to-one-or-more-pages-1014274390.html. Their examples use curl, but you should be able to make HTTP requests using the same authenticatedRequestFactory in your above script.
Key ideas:
