Hi @JConstantine , it is not possible to configure notifications by Issuetype unfortunately. There was a similar post recently and you might find a suggested work around useful - exclude-sub-task-creation-notification
I don't get it how to do this part:
Configure the post function "Update issue custom field" to update the field you created with the group containing all your users.
Also, I have found this:
So it looks like it's not possible to do paragraph 3.
