Hi Team!
Help me please for my problem :(
We need that fields calculated ("stp","def_prod") and write sum in fields ("adm","total").
We have this script in behaviour plugin:
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.fields.CustomField;
//Take fields by name
def stp = getFieldByName("cf1Name");
def adm = getFieldByName("cf2Name");
def total = getFieldByName("cf3Name");
def def_prod = getFieldByName("cf4Name");
//Take the value from the field and assign the type Double
def value_stp = stp.getValue() as Double
def value_def = def_prod.getValue() as Double
if (value_stp != null & value_def != null){
def sum_adm = (value_stp + value_def) * 0.15
adm.setFormValue(sum_adm)
total.setFormValue(value_stp + sum_adm)
else {
//Set null if value_stp\value_def = null
adm.setFormValue(null)
total.setFormValue(null)
Values are calculate. But after delete value fields ("stp", "def_prod") "adm" and "total" is not set null.
How cleaning Double field's value in Behaviour?
Best
Regards
I found error in my script.
When i cleared my custom fields they have type "String".
When i write value they have type "Double".
Because of this condition "if" not work and value in customfield not cleared.
Below correcte script:
def stp = getFieldByName("cfName");
if (stp.getValue() != "" && def_prod.getValue() != ""){
def sum_adm = ((stp.getValue() as Double) + (def_prod.getValue() as Double)) * 0.15
total.setFormValue((stp.getValue() as Double) + sum_adm)
else {
