How to Check JSP version Centos7
Moses Thomas
July 1, 2019
Dear All,
Does  any one know's how  to quickly check JSP version in  Centos 7/Linux
I would like to  download manual for a particular version.
I have checked the  /opt/jira/atlassian-jira/WEB-INF/web.xml  but nothing
Moses Thomas
July 3, 2019
@Lucy Adeke  I  checked the  version of Tomcat (Apache Tomcat/8.5.29)  and then mapped  it  to  the  JSP version which  is 2.3   and  the  latest version  is  2.3   since 2009.
more info here:  http://tomcat.apache.org/whichversion.html
But Thanks  for the hint!
best regards,
Mo
Lucy Adeke July 2, 2019
Hi Moses,
Refer to the compatible Java version for jira. This will guide you on the compatible servlets & JSP SDK Compiler.
Login to Jira --> System info --> Java Version.
Lucy
Lucy Adeke July 1, 2019
Hi Moses,
Did you mean to ask how to check the Java version?
If so type
java -version
In the terminal.
Lucy
Moses Thomas
July 2, 2019
@Lucy Adeke   Hi, thanks for  the reply
No, I meant the jsp(javaserver pages) version (a kind of java servlet) i see it has different versions but i want to  know the version my jira server is using so  that  i  can  get  the manual to understand  the syntax  for this  version.
