How to Create Custom Field of Text or Attachement - or Checklist
Phillip Yero
Is it possible to create a custom field that only displays text or one that has an attchement?
What I am trying to accomplish is, for a particlar project, have a field that will display the same text - or contain the same document - for every issue that is created.
The document is simply a checklist, so if there is a way to create checklist field, that would work too.
Anna Cardino
April 25, 2014
Hey there, Philip.
Would you consider the usage of third-party plugin? If yes, do check this one out.
https://marketplace.atlassian.com/plugins/ru.mail.jira.plugins.todolist
I came across a question which might be similar to the requirement that you have here as well:
https://answers.atlassian.com/questions/78149/how-do-i-implement-a-checklist-in-jira
Hope this helps!
