How to Export Linked issues with count along with issue details?
Nageswarara Rao
I have linked 10 issues in an issue by using more->link.
I want to export the linked issues count along with issue details while exporting issues .
Example :
Suppose the issue ST-1 has 10 issue,ST-2 has 20 issues as linked issues means I want to export data while searching issues as follows in excel sheet :
Issue Key summary Developername Tester name LinkedCount
ST-1 Test issue Developer1 tester1 10
ST-2 Testissue2 Developer2 tester2 20
Thanks in advance.
Pablo Beltran
April 1, 2014
This is almost supported by JIRA itself as the Issue Navigator exports issues to Excel and you can configure the issue details (columns) to export. If you include the linked issues column, then you would see the linked Issue keys (rather the amount), but it would be very simple making an Excel macro counting them.
Midori
April 1, 2014
Hi!
This is doable with the JIRA PDF View Plugin by developing a custom template. This is quite trivial actually, but make sure that you check out the following templates shipped with the plugin:
  1. the Project Status Report template shows you how you to display those exact fiels that you need
  2. it also shows you how to create a table layout from those
  3. the Traceability Matrix template's Groovy script demonstrates how to process (count in your case) linked issues
Something like this:
Help us plant more trees
