×Hi All,
I have been facing high cpu usage and i see the load on CPU ( consuming high cpu usage ) when multiple users are trying to create/requests( using clone-plus plugin ) at a time .
Jira version is : 6.2.7
No of Active users : 150
connection pool max size is 150
max idle size is 80
JVM memory = 18GB ( out of total RAM 32 GB)
Could anyone help on controlling the high cpu usage .
Regards
Hi Shrikanth,
There are other factors to assess and consider to fine tune the server resources allocation for JIRA application, e.g: custom fields, third-party add-ons etc.
Going forward, I would suggest identifying the cause of the CPU spike before we plan ahead:
for i in $(seq 6); do top -b -H -p $pid -n 1 > app_cpu_usage.date +%s.txt; kill -3 $pid; sleep 10; done
Kelly
Hi Kelly,
Sorry for the delay in reply .. i have gone though the logs and observed that the CPU usage is getting high when Clone-plus plugin is being used ,which copies the existing issue along with sub tasks( min of 10) and CPU goes high when multiple users ( 2 or 3 ) try to use clone-plus at a time .
our jira version(6.2.7) licence is expired and so the plugin cannot be updated to next version until jira is upgraded.
Please help if there is a way( workaround ) to fix the issue.
Let me know if any other details are required.
Thanks in Advance
Regards
Hi Srikanth,
If you have confirmed that the third-party plugin cause the CPU spike, it's worth engaging the third-party vendor Support to look into the issue as it might be a known issue pertain to the release you are running on.
Kelly
Hi Every one,
I have been facing the high CPU usage again even after increasing the Jira instance memory to 32GB ( total 64 GB). still we are facing the High CPU usage and application outage.
Can any one suggest on reducing the High CPU usage ?
Below are the connection pool details.
<pool-min-size>100</pool-min-size>
<pool-max-size>100</pool-max-size>
<pool-max-wait>60000</pool-max-wait>
<pool-max-idle>100</pool-max-idle>
<pool-remove-abandoned>true</pool-remove-abandoned>
<pool-remove-abandoned-timeout>300</pool-remove-abandoned-timeout>
Regards
Srikanth
