How to Implement Board Admin Removal through jira plugin
Jyoti Kumari
Hello Everyone,
I have referred below document for board admin removal and it is working fine ,but facing issue to implement the same through jira plugin.
https://community.atlassian.com/t5/Jira-questions/Remove-User-from-Project-Roles-and-Board-Administrators/qaq-p/2902442#M1077284
The Answer provided by @Vitali Basarevski    is working perfectly as per my scenario.I have tried to add below dependency and tried my adding package.My plugin is using spring scanner annotation but still not working.Kindly suggest and how to fix issue or how we can implement these scenario through plugin.
<dependency>
<groupId>com.atlassian.jira.plugins</groupId>
<artifactId>jira-greenhopper-plugin</artifactId>
<version>6.7.7</version>
<scope>provided</scope>
</dependency>
<instructions>
<Import-Package>
org.springframework.osgi.*;resolution:="optional",
com.atlassian.greenhopper.*,
</Import-Package>
</instructions>
Thanks and Regards,
Jyoti
Jyoti Kumari
Vitali Basarevski December 30, 2024
Hi @Jyoti Kumari
Hello.
I think you will find this article useful. How to use Jira Software functionality in a Jira plugin
Please have a look at it.
You should use the up-to-date version of the plugin (for your Jira version). Check this mvn repo for detailed plugin info.
Hope this helps.
Vitali
Jyoti Kumari
I have followed doc-How to use Jira Software functionality in a Jira plugin, but it is not help full. It has generated jar file locally named as 'jira-greenhopper-plugin-9.12.10_1718170898000.jar',but these one is not available in maven, even I tried latest dependency from maven(https://mvnrepository.com/artifact/com.atlassian.jira.plugins/jira-greenhopper-plugin/1000.571.0),but still not working.Locally I am not getting any compile time error, but deploying to server, getting below error message-
<custom_plugin_name> has timed out waiting for (&(objectClass=com.atlassian.greenhopper.service.rapid.view.BoardAdminService)(objectClass=com.atlassian.greenhopper.service.rapid.view.BoardAdminService)).Kindly suggest a way to fix or to implement it in a different way
Sunny Ape
December 30, 2024 edited
Given no such 'exact' version 6.7.7 of the old Greenhopper plugin exists in the Maven repository, then it should come as no surprise at all that your plugin "doesn't work".
Even if there was, it would be almost half a decade old, so you'd have to be half crazy to try using it with Jira DC v9.12.x !
Jyoti Kumari
I tried different version, but still not working.Can you suggest ,how to fix it.
SERVER
VERSION
9.12.15
Learn more
