×I have a custom field, Select List- Multi Choice which appears like this for example:
one, two, three, four
Can I make it appear like:
one
two
three
four
thanks!
Depending on the purpose of the field, I'd suggest a free checklist app, e.g. https://marketplace.atlassian.com/apps/1216137/agility-checklist-for-jira-free?hosting=server&tab=overview
Paid apps give you even more functionality - https://marketplace.atlassian.com/search?hosting=server&product=jira&query=checklist
Hope that helps
ty - we have checklist.. this is not a checklist field.. This is select list with multi options.
Hi Julie,
If it's not a checklist field, then I would agree with @sukkeong
Ok on checklist totally get it.. Is there a way to add a Jira filter with Checklist field to Confluence and have it appear on separate lines? ty!
Which checklist app do you have? Some checklist apps allow JQL, but not all.
Great app :) Check out this documentation: https://okapya.atlassian.net/wiki/spaces/CHKDOC/pages/270565415/Searching+for+Checklists
I'm not sure what the name of your checklist custom field is, but you can use JQL in the form of:
"Definition of Done"
= allItemsUnchecked()
or something like that.
Unfortunately, the custom field included in JIRA does not provide such an option. I am guessing the design decision is to efficiently use the available screen real-estate.
If there is no alternative in the Marketplace, you might need to develop your own plugin, https://developer.atlassian.com/server/jira/platform/custom-field/.
