How to Set current assignee to "Unassigned" whenever group picker field is changed?
CMCSS Programmers April 11, 2017
I have a group picker field called "Assigned Team." Whenever someone changes the group in the group picker to any group, how can I automatically set the Assignee back to "Unassigned"? Not sure how to do this in either a Behaviour or Script Listener? Thank you.
Chris C
May 15, 2018
Try this using a IssueInputParameters object.
import org.apache.log4j.Logger
import org.apache.log4j.Level
import com.atlassian.jira.bc.issue.IssueService
import com.atlassian.jira.issue.link.IssueLinkTypeManager
import com.atlassian.jira.issue.IssueInputParameters
import com.atlassian.jira.issue.IssueManager
IssueService issueService = ComponentAccessor.getComponent(IssueService);
def user = ComponentAccessor.getJiraAuthenticationContext().loggedInUser
IssueInputParameters issueInputParameters = issueService.newIssueInputParameters()
issueInputParameters.setAssigneeId(null)
def update = issueService.validateUpdate(user, issue.id, issueInputParameters)
log.debug "${issueInputParameters}"
if (update.isValid()) {
          issueService.update(user, update)
} else {
         log.debug("issue parameters are not valid: ${update}")
Kumar
January 18, 2019
Hi @CMCSS Programmers @Chris C @Jason Huntowski @Ron Gates
For me also have same requirement i have group field called "Assignment Group"
when ever the group field changes the assignee field have to change to "Unassigned"
I have tried above scripts it did not worked for me I have added those scripts in "Script Listener" Custom Event "Issue Update"
Can you please help me here how you guys achieved this
Kumar
Ron Gates
April 11, 2017 edited
You can go with Custom Listener and configure it to trigger on "Issue Update" event (or any events combination of your choosing):
import com.atlassian.jira.issue.CustomFieldManager
def currentIssue = event.issue;
def customFieldManager = ComponentAccessor.getCustomFieldManager();
def groupField = customFieldManager.getCustomFieldObjectByName('Group Field');
def groupFieldValue = currentIssue.getCustomFieldValue(groupField);
if (groupFieldValue != null) {
 currentIssue.setAssignee(null);
Note that ScriptRunner inline script syntax checker can see an error in the line that sets assignee but script will work fine without errors.
Jason Huntowski
Hey Ron,
I have a similar need but your response is not working. I pasted my code below. My situation is that I am using a global listener to clear the assignee field if a custom field changes. I know my change code works, cause I use it for changing priority based on the change. But I can't get the assignee to null out.
def change = event?.getChangeLog()?.getRelated("ChildChangeItem").find {it.field == "Assignment Group"}
if(change)
currentIssue.setAssigneeId(null);
return true
else return false
 any help you could give would be much appreciated.
Jason
Like • Rajaravikiran S likes this
atlassian, team ’25 europe guide, teamwork collection, atlassian events, conference guide, team culture, collaboration tools, ai in teamwork, atlassian learning, event schedule, keynote previews, community events
Must attend events for Team Europe '25!
Make the most of your time in Barcelona with our curated guide – discover how Jira, Confluence, Loom, and Rovo work better together, connect with Atlassian experts, and enter to win an Apple prize bundle!
Get the guide
