Hi
As a Jira administrator, our process requirement is below:
Jira user create an issue, then following process step should'nt change any the original fields which the first user filled even the issue is possible?
E.g : I have create an issue with date filed, I put the date no one can't edit the field is Possible ?
thanks in advance.
