How to Set some fields as read only after submit an issue?
linqiang
As a Jira administrator, our process requirement is below:
Jira user add an issue, then following process step should'nt change any the original fields which the first user filled even the issue iniator?
thanks in advance.
10 votes
Nic Brough -Adaptavist-
December 6, 2012
I wouldn't worry about the behaviours plugin, you can do it without that
Look at the "screen schemes" and set up a "create" screen which contains all the fields, and then have the "edit" screen exclude them. People won't be able to change the original fields.
Sorin Sbarnea (Citrix)
January 20, 2014
How about the inplace-edits?
January 20, 2014
As I said, don't put them on the "edit" screens.
Jira only allows in-place edit on fields that are on the "edit" screen.
Nasrin February 2, 2015
I don't have separate screens for create and edit
Mario Günter
February 3, 2015
Hi. If I remove the fields from "edit" screen they aren't shown in issue view anymore.
February 3, 2015
That suggests that you are using the same screen for edit and view. Separate them out. Same for the previous comment - you need separate screens for create and edit. Copy the existing one, then change the issue type screen scheme so it uses the new screen for edit and change that copy.
Mario Günter
February 3, 2015
Hi Nic, thank you. I got it... I mixed 'em up...
Nasrin February 3, 2015
Thank You.. I have separated the screen for edit and create.. then removed unwanted fields from edit screen.. working fine..
Naren
December 6, 2012
Just have a look at the Behaviours Plugin. You can make fields read only using this plugin.
You may like to read the documentation here. Hope this helps.
linqiang
thanks.
i prefer create screen schemes, but if the issue initator want to edit, it also cann't editable,
the Behaviours Plugin cannot linked the readonly with workflow steps/transition, it only link certain roles.
any ideas?
December 6, 2012
Your original question said that no-one should be able to edit the fields after initial creation.
But that's still possible with screen schemes, as long as you're happy with a slightly ugly hack.
Basically, you move "edit" into the workflow. Do what I said already, but then add a third screen to the system, one that includes all the fields you want to edit (you could just use the "create" screen for this of course). Then, go into the workflow, and on each step, add a transtion that loops back to the same step. Use the new screen for the transition. Finally, put "conditions" on the transition - the one you need to begin with is "only the reporter of the issue can do this transition"
linqiang
Great, that works.
thanks you.
Mike Sorensen
June 9, 2014
This doesn't seem to prevent the user from adding attachments. If Attachments isn't in the Edit screen, they still have other mechanisms to make attachments from the View screen.
June 9, 2014
Correct. Attachments is not a field, it's a way of attaching files.
Attachment rights are controlled at a project level, by permissions.
Help us plant more trees
