How to Use JIRA & Confluence to Caculate This Kind of Statics?
xinan liu
I want to know how to achieve this function by JIRA & Confluence.
  • The average Resolution time of Project issues (in a month):
     (ResolutionDate - CreatedDate)/Closed issue number(in a month)
  • Ratio of issue Resolved by someone:
     Resolved issues' number by someone/All the issues someone was assigned to
  • Issues' number which Resolved by someone
  • the number of every Developers which issue's ResolutionDate >= Duedate
Thanks very much!
CelesteCS
Hello!
The most convenient way I see is using JIRA Issues macro as a macro to get needed information from JIRA into Confluence and perform some post-calculations over it.
For any calculations in Confluence, including any manipulations with output of third party macros, like JIRA Issues macro, you may use CelesteCS Math for Confluence.
There is a plenty of other functions in the macro, so you may perform any calculations using formulas in EXCEL style.
Jason Plumhoff
July 21, 2015
There are probably several ways to get this information, but I found it easiest to use the Better Excel JIRA plugin to craft custom reports showing what I wanted to see.  The plugin lets you upload excel templates (with pivot tables, charts, etc.), and you can even have it fire off groovy scripts to do really involved calculations.
