How to Use JQl to color cards
Stephen Fell September 13, 2017
Hey Everyone,
I'm new to Jira and im trying to get the most out of the tool and wanted to use the "card colours" feature so i can colour cards in the activity sprint view to change colour based on a field called "due date" however having never used JQL and being new to Jira im unsure where to start, essentially im trying to achieve the following:
  • Colour = RED when the the due date of the card is today or within 3 days
  • Colour = Amber when the due date of the card is within 5 days of today
  • Colour = Green when the due date of the card is 6 or more days  from today
Any help you can offer to help me achieve the above outcome would be much appreciated.
4 votes
Warren
September 13, 2017
You will need to have project Admin rights to do this.
Go to Board settings and click on Card colours. From the dropdown select Queries, then add your JQL for each different colour. N.B. the order is important because it will use the first colour where the condition matches, so drag the items to reorder.
Thanks for the reply.
Ive got that far the bit I'm struggling with is what JQL code I need to use to make it happen
Warren
September 13, 2017
Ah, let's try and get that sorted then.
Colour = RED. The JQL is  duedate <= 3d
Colour = Amber. The JQL is duedate <= 5d
Colour = Green. The JQL is duedate <= 6d
I think I'm right in saying that they need to be done in this order, but play around with it and see
Like • 2 people like this
Daniel
August 25, 2021 edited
It seems they are evaluated from top to bottom, with the first match deciding the colour
Like • Anoop VK likes this
Lourdes Valladares
July 30, 2021
Hi there!
It happened to me that colours were being overwritten because the biggest condition applied to everything, I added a "between" range to fix it:
Colour = RED: The JQL is  duedate <= 3d
Colour = Amber: The JQL is duedate <= 5d AND duedate >= 3d
Colour = Green: The JQL is duedate <= 6d AND duedate >= 5d
I hope this helps someone with my same issue.
drazorenov January 19, 2023
in last two options better use '>' indeed '>='
Frank Collazo
April 1, 2024 edited
So the syntax would be objectType = ASSET NAME AND color=RED AND duedate >=-30d between duedate <=30d?
Francisco Soto
January 9, 2023
With the new UI I can't find the option under Board settings > Card colours.
Any suggestions?
Marc - Devoteam
March 7, 2024
Hi @Francisco Soto
This can only be done on boards in company managed projects.
This is not an option in team managed projects
Stephen Fell September 15, 2017
Super thanks for the help, that id the trick :)
