Hi @Prasad Netaji N ,
Here is a link to the api https://docs.atlassian.com/software/jira/docs/api/REST/8.5.3/?_ga=2.53176872.1805901695.1579239025-315489623.1565892084#api/2/permissionscheme
You can use any scripting language that suits you and that allows to do REST calls to create the script.
How to use scripting language and include REST calls to edit permision scheme perticular
That depends on the language and what you want to do.
But I think without general knowledge in writing scripts you will not achieve what you want.
The complete list of supported rest endpoints related to permissions schemes can be found here:
