How to Write update query in Jql
Sachin Dhamale
Hello; I want to update my jira's hsql database using update query. my update query is "Update tree set child=replace(child,3.7,2) where projectid=SAC" here- tree-Table Name Child-Custom filed Column name projectid-Column name Can anyone tell me how to write this query using Jql querybuilder
Peter Van de Voorde
Udo is correct in the fact that you can not use JQL for anything else than select queries.
The following page explains how you can run your sql commands directly in the HSQL database:
https://confluence.atlassian.com/display/JIRA/Running+SQL+commands+in+a+HSQL+database
I hope this helps you out.
Best Regards,
Peter
Kiran L V
June 12, 2019
It would have been of great help.  Unfortunately it is limited to Select at this time.
Udo Brand
July 30, 2013
As far as I know you can't use JQL for updating issues. It is just for querying issues - not like SQL where you have different DML options (Select, Insert, Update, Delete)
