Just install the gantt chart plugin but not able to access gantt chart...
There's not enough information to help you here. Have you checked that the plugin is installed (i.e. on the list of plugins and not greyed out as disabled)? What have you done to try to "access" it? How have you configured it? (If those all make sense and you think they're ok, then could you also have a look at the log)
Also, there's more than one Gantt chart plugin out there - could you tell us which one you're using?
