How to access Status Category in groovy script
Nic Stransky June 6, 2017
I can get the status of an issue, but I can't figure out how to get the status category (To do, In Progress, Done).
Can someone please help?
Nic - if you're out there.
3 votes
Nic Brough -Adaptavist-
June 6, 2017
If you've got the status, you're half-way there!
Given an issue, I've used
def sc = issue.getStatus().getStatusCategory()
You'll probably want to try
  • sc.getColorName()
  • sc.getAliases()
  • sc.getName()
and so-on for the actual data
Thanks!!!!!  Man google was NO help on this one. Can't believe it hadn't been documented before anywhere.
Is there a primary reference for Groovy script methods? I found one page but it was really hard to search and navigate so I wasn't able to drill down to anything related to category.
June 6, 2017
It's not really Groovy doing this.  The "def" bit is Groovy, letting you create an untyped variable to work with later, but the rest is Java calls into the JIRA AP.
If you go to https://docs.atlassian.com/jira/server/ you'll see the java documentation for JIRA's API.
In the code, you've got an "issue" object, so go find the class for "issue" in the "all classes" panel and click on that.  The detail panel will show you the available methods  and what they return.  So getStatus() returns a Status object, so you click on that to see that object and then you'll see the getStatusCategory() call fetches a statusCategory and that has the three get methods I suggested trying!
I suspect Google was less help than usual because the getStatusCategory call is relatively new and may not have been widely posted yet.
Tomáš Vrabec
September 20, 2019 edited
@Nic Brough -Adaptavist- thanks for that even in 2019
Not sure if its funny or sad, but if you run
issue.getStatus().getStatusCategory().getName()
over an issue which is in Status which is "Done" Status Category you will get a string "Complete"  ¯\_(ツ)_/¯
Thanks man!
Like Nic Brough -Adaptavist- likes this
September 20, 2019
Yeah, that is really odd. As you say: ¯\_(ツ)_/¯
Uday Kiran Bhaviri March 23, 2022
We can use getTranslatedName() to get exact category i.e "Done" instead of "Complete"
issue.getStatus().getStatusCategory().getTranslatedName()
Register here ⬇️
