How to access the issue in ScriptRunner custom listener?
Marketa Dvorackova
Hi guys,
I am trying to implement a custom listener with ScriptRunner and I am not able to get to the issue for which the event I'm listening to fired.
Logging with
log.debug "Event: ${event.getEventTypeId()} fired for ${event.issue} and caught by MyListener"
I get the right info. The issue object, as I understand from documentation, should be accessible without declaring it. But even if I try a simple
log.debug issue.getId()
it gives me the following error in the log
'java.lang.RuntimeException: No such property: issue for class: com.custom.MyListener'
I can't figure out what I'm missing. Does someone have an idea please?
Thanks a lot
Marc Minten (EVS)
June 10, 2015
You sould use
event.issue.getId()
or
def myIssue = event.issue
myIssue.getId()
Marketa Dvorackova
Thanks Marc. I had tried that before, but it gave me an error. Something like "trying to access internal protected parameter". I guess I had something else wrong in the code. Works like a charm.
