I Need to create a Radio Button Field with Yes/No options. With Yes I need to add a text with Hyperlink in it.
For example:
Hi Vasanta,
Currently, it's not possible to add links to custom fields options since it uses basic text renderer, so any link added will not be rendered.
For this type of field, it's not possible to change the renderer the same as the other fields like comment and description, for example, so any picker field will use the basic text renderer.
Hope this clarifies.
If you have any other question, please let us know.
Angélica
Hi Angelica,
Thanks for your help.
But I found out the solution, which worked.
In option, I provided <a href="url link" target="_blank">here</a> and it worked.
Hi Vasanta,
Thank you for share the solution with us!
Hope you have a great weekend.
Angélica
Register now
