I am trying to use the Traceability Matrix function to create subpages for my Test Cases so that I can run them numerous times without having to modify the original page. When I run my query and go to import as a macro, I have to manually add the RY Test Result macro for each test case I have ported over to the subpage. Is there a way to add the macro in bulk?
When Highlighting multiple cells and attempting to add the macro, it is only added to the last cell that was selected. I know with requirements, when highlighting multiple cells and adding the macro with Alt+Shift+R you can create an ID for each cell that was selected. Does a similar hotkey or function exist with the Ry Test Result macro?
Additionally, is there a better way to perform the primary function without having to go through the Traceability Matrix?
