HI All,
I got a requirement to create new project (copying from existing one) that there are almost 20 fields needed in a project which are completely new, so for this i created custom fields for all
but i cant use the field configuration of existing one as it has more required fields, I created new field configuration copying the old one
created new screens for this project and custom fields are associated with those,
but my question is how the new fields will be added to the new field configuration in order to make those required
@KoteswaraRao Gudla - ConsultantOnce you have created these custom fields , they will be in the new field configuration, and even if you make a copy the will appear there. All you need to do now is to use this field configuration for the screen scheme by adding custom fields to screen for the issue type you want to use.
Best!
You have to add those fields to a screen before
